Monotonization of flux, entropy and numerical schemes for conservation laws - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
Using the concept of monotonization, families of two step and k-step finite volume schemes for scalar hyperbolic conservation laws are constructed and analyzed. These families contain the Force scheme and give an alternative to the Musta scheme. These schemes can be extended to systems of conservation law
RR-6787.pdf (249.39 Ko) Télécharger le fichier
inria-00349637 , version 1 (03-01-2009)
  • HAL Id : inria-00349637 , version 1
Adimurthi Adimurthi, G.D. Veerappa Gowda, Jérôme Jaffré. Monotonization of flux, entropy and numerical schemes for conservation laws. [Research Report] RR-6787, INRIA. 2008, pp.18. ⟨inria-00349637⟩
62 Consultations
194 Téléchargements
