s'authentifier
version française rss feed
inria-00350025, version 1
Routing Reconfiguration/Process Number: Networks with Shared Bandwidth.
David Coudert () 1, Dorian Mazauric () 1, Nicolas Nisse () a1
N° RR-6790 (2009)
Résumé : In this paper, we address the problem of scheduling the switching of a set of connection requests one after the other from current routing to another pre-determined routing. We propose a model that handles requests using only a constant fraction of the bandwidth of a link, thus generalizing the model proposed in~\cite{CoSe07,JoSo03} for WDM networks. Our main result is the proof that the problem of deciding whether it exists a scheduling of the rerouting of connection requests without traffic interruption is NP-complete even if requests use the third of the bandwidth of a link. Note that the problem is polynomial when the bandwidth of a link cannot be shared~\cite{CoSe07}.
  • Domaine : Informatique/Réseaux et télécommunications
  • Référence interne : RR-6790
  • inria-00350025, version 1
  • oai:hal.inria.fr:inria-00350025
  • Contributeur :
  • Soumis le : Lundi 5 Janvier 2009, 16:36:22
  • Dernière modification le : Mercredi 7 Janvier 2009, 19:02:45
tous les articles de la base du CCSd...
