s'authentifier
version française rss feed
inria-00350284, version 1
Statistically robust 2D visual servoing
Andrew Comport () a1, E. Marchand a1, François Chaumette () a1
IEEE Trans. on Robotics 22, 2 (2006) 415-421
Résumé : A fundamental step towards broadening the use of real world image-based visual servoing is to deal with the important issue of reliability and robustness. In order to address this issue, a closed loop control law is proposed that simultaneously accomplishes a visual servoing task and is robust to a general class of image processing errors. This is achieved with the application of widely accepted statistical techniques such as robust M-estimation and LMedS. Experimental results are presented which demonstrate visual servoing tasks that resist severe outlier contamination.
  • Domaine : Informatique/Robotique
  • inria-00350284, version 1
  • oai:hal.inria.fr:inria-00350284
  • Contributeur :
  • Déposé pour le compte de :
  • Soumis le : Mardi 6 Janvier 2009, 13:56:35
  • Dernière modification le : Mercredi 7 Janvier 2009, 18:29:00
tous les articles de la base du CCSd...
