Visual Servoing of an Airplane for Alignment with respect to a Runway - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
In this paper, we propose a visual servoing scheme to align an airplane with respect to a runway. A linearized model of the airplane dynamics and decoupled visual features are designed to build the control scheme. Simulation results are obtained with a quite realistic flight simulator which is based on a non linear airplane dynamic model. They show that the airplane realizes correctly the specified task by using visual data.
2007_icra_bourquardez.pdf (372.68 Ko) Télécharger le fichier
inria-00350635 , version 1 (07-01-2009)
  • HAL Id : inria-00350635 , version 1
O. Bourquardez, François Chaumette. Visual Servoing of an Airplane for Alignment with respect to a Runway. IEEE Int. Conf. on Robotics and Automation, ICRA'07, 2007, Rome, Italy. pp.1330-1335. ⟨inria-00350635⟩
156 Consultations
222 Téléchargements
