Experimental evaluation of an urban visual path following framework - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Robot cars will likely play an important role in the future. In this paper a visual path following framework for urban environments is experimentally evaluated. The framework's hybrid topological-metric approach for representing the environment provides stable interest points for image-based visual servoing during navigation. The presented experimental results with a robot car show that the framework is robust against changing illumination and moving objects covering up parts of the field of view of the monocular camera. Furthermore, there is no need to perform bundle adjustment nor to use odometry.
2007_iav_diosi.pdf (354.17 Ko) Télécharger le fichier
inria-00350643 , version 1 (07-01-2009)
  • HAL Id : inria-00350643 , version 1
A. Diosi, A. Remazeilles, S. Segvic, François Chaumette. Experimental evaluation of an urban visual path following framework. 6th IFAC Symposium on Intelligent Autonomous Vehicles, IAV'07, 2007, Toulouse, France. ⟨inria-00350643⟩
201 Consultations
270 Téléchargements
