s'authentifier
version française rss feed
inria-00350650, version 1
Full motion tracking in ultrasound using image speckle information and visual servoing
A. Krupa a1, G. Fichtinger b2, G. Hager b2
IEEE Int. Conf. on Robotics and Automation, ICRA'07 (2007) 2458-2464
Résumé : This paper presents a new visual servoing method that is able to stabilize a moving area of soft tissue within an ultrasound B-mode imaging plane. The approach consists of moving the probe in order to minimize the relative position between a target imaging plane and the ultrasound plane observed by the probe of the moving tissue target. The problem is decoupled into motion out-of-plane and motion within plane. For the former, a new original method based on the speckle information contained in the images is developed. For the latter, an image region tracker is used to provide the in-plane motion. A visual servoing control scheme is then developed to perform the tracking robotic task. The method is validated on simulated motions of a probe on a static ultrasound volume acquired from a phantom.
  • Domaine : Informatique/Robotique
  • inria-00350650, version 1
  • oai:hal.inria.fr:inria-00350650
  • Contributeur :
  • Déposé pour le compte de :
  • Soumis le : Mercredi 7 Janvier 2009, 14:27:09
  • Dernière modification le : Dimanche 11 Janvier 2009, 14:28:44
tous les articles de la base du CCSd...
