An image-based visual servoing scheme for following paths with nonholonomic mobile robots - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
We present an image-based visual servoing con- troller enabling nonholonomic mobile robots with a fixed pinhole camera to reach and follow a continuous path on the ground. The controller utilizes only a small set of features extracted from the image plane, without using the complete geometric representation of the path. A Lyapunov-based stability analysis is carried out. The performance of the controller is validated and compared by simulations and experiments on a car-like robot equipped with a pinhole camera.
2008_icarcv_cherubini.pdf (1.7 Mo) Télécharger le fichier
inria-00351859 , version 1 (12-01-2009)
  • HAL Id : inria-00351859 , version 1
Andrea Cherubini, François Chaumette, G. Oriolo. An image-based visual servoing scheme for following paths with nonholonomic mobile robots. Int. Conf. on Control, Automation, Robotics and Vision, ICARCV 2008, 2008, Hanoi, Vietnam, France. pp.108-113. ⟨inria-00351859⟩
284 Consultations
618 Téléchargements
