A position-based visual servoing scheme for following paths with nonholonomic mobile robots - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
We present an image-based visual servoing con- troller enabling nonholonomic mobile robots with a fixed pinhole camera to reach and follow a continuous path on the ground. The controller utilizes only a small set of features extracted from the image plane, without using the complete geometric representation of the path. A Lyapunov-based stability analysis is carried out. The performance of the controller is validated and compared by simulations and experimpinhole camera.
2008_iros_cherubini.pdf (759.68 Ko) Télécharger le fichier
inria-00351860 , version 1 (12-01-2009)
  • HAL Id : inria-00351860 , version 1
Andrea Cherubini, François Chaumette, G. Oriolo. A position-based visual servoing scheme for following paths with nonholonomic mobile robots. IEEE/RSJ Int. Conf. on Intelligent Robots and Systems, IROS 2008, 2008, Nice, France, France. pp.1648-1654. ⟨inria-00351860⟩
361 Consultations
380 Téléchargements
