s'authentifier
version française rss feed
inria-00351865, version 1
Catadioptric visual servoing from 3D straight lines
H. Hadj-Abdelkader 1, Y. Mezouar 1, P. Martinet a1, François Chaumette () b2
IEEE Trans. on Robotics 24, 3 (2008) 652-665
Résumé : In this paper, we consider the problem of controlling a 6 DOF holonomic robot and a nonholonomic mobile robot from the projection of 3-D straight lines in the image plane of central catadioptric systems. A generic central catadioptric interaction matrix for the projection of 3-D straight lines is derived using an unifying imaging model valid for an entire class of cameras. This result is exploited to design an image-based control law that allows us to control the 6 DOF of a robotic arm. Then, the projected lines are exploited to control a nonholonomic robot. We show that as when considering a robotic arm, the control objectives are mainly based on catadioptric image feature and that local asymptotic con- vergence is guaranteed. Simulation results and real experiments with a 6 DOF eye-to-hand system and a mobile robot illustrate the control strategy.
  • Domaine : Informatique/Robotique
  • inria-00351865, version 1
  • oai:hal.inria.fr:inria-00351865
  • Contributeur :
  • Déposé pour le compte de :
  • Soumis le : Lundi 12 Janvier 2009, 10:10:00
  • Dernière modification le : Lundi 12 Janvier 2009, 12:01:40
tous les articles de la base du CCSd...
