s'authentifier
version française rss feed
inria-00351886, version 1
Voir la fiche détaillée  BibTeX  EndNote  TEI  RefWorks
Efficient model-based tracking for robot vision.
Andrew Comport () a1, E. Marchand a1, François Chaumette () a1
(2005)
Icone de 2005_ar_comport.pdf
Advanced Robotics 19, 10 (2005) 1097-1113
This paper proposes a real-time, robust and efficient 3D model-based tracking algorithm. A virtual visual servoing approach is used for monocular 3D tracking. This method is similar to more classical non-linear pose computation techniques. A concise method for derivation of efficient distance-to-contour interaction matrices is described. An oriented edge detector is used in order to provide real-time tracking of points normal to the object contours. Robustness is obtained by integrating a M-estimator into the virtual visual control law via an iteratively re-weighted least squares implementation. The method presented in this paper has been validated on several visual servoing experiments considering various objects. Results show the method to be robust to occlusion, changes in illumination and miss-tracking.
a –  INRIA
1 :  LAGADIC (INRIA - IRISA)
CNRS : UMR6074 – INRIA – Université de Rennes 1
Informatique/Robotique
Special issue on Selected papers from IROS'04
