Visual servoing with respect to complex objects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
This paper presents new advances in the field of visual servoing. More precisely, we consider the case where complex objects are observed by a camera. In a first part, planar objects of unknown shape are considered using image moments as input of the image-based control law. In the second part, a pose estimation and tracking algorithm is described to deal with real objects whose 3D model is known. For each case, experimental results obtained with an eye-in-hand system are presented.
2004_isr_comport.pdf (1.05 Mo) Télécharger le fichier
inria-00352022 , version 1 (12-01-2009)
  • HAL Id : inria-00352022 , version 1
Andrew Comport, O. Tahri, E. Marchand, François Chaumette. Visual servoing with respect to complex objects. Int. Symp. on Robotics, ISR'04, 2004, Paris, France, France. ⟨inria-00352022⟩
246 Consultations
76 Téléchargements
