Robust model-based tracking for robot vision - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
This paper proposes a real-time, robust and efficient 3D model-based tracking algorithm for visual servoing. A virtual visual servoing approach is used for monocular 3D tracking. This method is similar to more classical non-linear pose computation techniques. A concise method for derivation of efficient distance-to-contour interaction matrices is described. An oriented edge detector is used in order to provide real-time tracking of points normal to the object contours. Robustness is obtained by integrating a M-estimator into the virtual visual control law via an iteratively re-weighted least squares implementation. The method presented in this paper has been validated on several 2D 1/2 visual servoing experiments considering various objects. Results show the method to be robust to occlusion, changes in illumination and miss-tracking.
2004_iros_comport.pdf (1.04 Mo) Télécharger le fichier
inria-00352025 , version 1 (12-01-2009)
  • HAL Id : inria-00352025 , version 1
Andrew Comport, E. Marchand, François Chaumette. Robust model-based tracking for robot vision. IEEE/RSJ Int. Conf. on Intelligent Robots and Systems, IROS'04, 2004, Sendai, Japan. pp.692--697. ⟨inria-00352025⟩
202 Consultations
351 Téléchargements
