An efficient method to compute the inverse Jacobian matrix in visual servoing
The paper presents a method for estimating the inverse Jacobian matrix of a function, without computing the direct Jacobian matrix. The resulting inverse Jacobian matrix is shown to perform much better in modelling a relation $\theta= f^{-1}(x)$ than the classical Moore-Penrose inverse $J^+_f$ . Theoretical insight as well as comparisons in the domain of visual servoing are provided to demonstrate this assertion.
Robotique [cs.RO]
