A cinematography system for virtual storytelling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
In this paper we introduce a complete framework to automatically generate cinematographic view of dynamic scenes in real-time. The main goal of such a system is to provide a succession of shots and sequences (of virtual dynamic scenes) that can be related to pure cinema. Our system is based on the use of an image-based control of the camera that allows different levels of visual tasks and a multi-agent system that controls those cameras and selects the type of shot that has to be performed in order to fulfill the constraints of a given cinematographic rule (idiom). This level of adaptation constitutes the major novelty of our system. Moreover, it stands for a convenient tool to describe cinematographic idioms for real-time narrative virtual environments.
ICVS2003.pdf (114.62 Ko) Télécharger le fichier
inria-00352080 , version 1 (12-01-2009)
  • HAL Id : inria-00352080 , version 1
Nicolas Courty, Fabrice Lamarche, Stéphane Donikian, E. Marchand. A cinematography system for virtual storytelling. Int. Conf. on Virtual Storytelling, ICVS'03,, 2003, Toulouse, France, France. pp.30-34. ⟨inria-00352080⟩
232 Consultations
449 Téléchargements
