Mechanized semantics for the Clight subset of the C language - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Automated Reasoning Année : 2009
This article presents the formal semantics of a large subset of the C language called Clight. Clight includes pointer arithmetic, "struct" and "union" types, C loops and structured "switch" statements. Clight is the source language of the CompCert verified compiler. The formal semantics of Clight is a big-step operational semantics that observes both terminating and diverging executions and produces traces of input/output events. The formal semantics of Clight is mechanized using the Coq proof assistant. In addition to the semantics of Clight, this article describes its integration in the CompCert verified compiler and several ways by which the semantics was validated.
paper.pdf (222.69 Ko) Télécharger le fichier
inria-00352524 , version 1 (13-01-2009)
Sandrine Blazy, Xavier Leroy. Mechanized semantics for the Clight subset of the C language. Journal of Automated Reasoning, 2009, 43 (3), pp.263-288. ⟨10.1007/s10817-009-9148-3⟩. ⟨inria-00352524⟩
285 Consultations
332 Téléchargements
