Potential problems of stability and convergence in image-based and position-based visual servoing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 1998
Visual servoing, using image-based control or position-based control, generally gives satisfactory results. However, in some cases, convergence and stability problems may occur. The aim of this paper is to emphasize these problems by considering an eye-in-hand system and a positioning task with respect to a static target which constrains the six camera degrees of freedom.
Mots clés
1998_lncis_chaumette.pdf (235.57 Ko) Télécharger le fichier
inria-00352553 , version 1 (13-01-2009)
  • HAL Id : inria-00352553 , version 1
François Chaumette. Potential problems of stability and convergence in image-based and position-based visual servoing. Kriegman, D. and Hager, G and Morse, A.S. The Confluence of Vision and Control, LNCIS Series, No 237, Springer-Verlag, pp.66-78, 1998. ⟨inria-00352553⟩
520 Consultations
2880 Téléchargements
