Complex object tracking by visual servoing based on 2D image motion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1998
Efficient real-time robotic tasks using a monocular vision system were previously developed with simple objects (e.g. white points on a black background), within a visual servoing context. Due to recent developments, it is now possible to design real-time visual tasks exploiting motion information in the image, estimated by robust algorithms. This paper proposes such an approach to track complex objects, such as a pedestrian. It consists in integrating the measured 2D motion of the object to recover its 2D-position in the image. The principle of the tracking task is to control the camera pan and tilt such that the estimated center of the object appears at the center of the image. Real-time experimental results demonstrate the efficiency and the robustness of the method.
Mots clés
1998_icpr_cretual.pdf (396.7 Ko) Télécharger le fichier
inria-00352563 , version 1 (13-01-2009)
  • HAL Id : inria-00352563 , version 1
Armel Crétual, François Chaumette, Patrick Bouthemy. Complex object tracking by visual servoing based on 2D image motion. Int. Conf on Pattern Recognition, ICPR'98, 1998, Brisbane, Australia, Australia. pp.1251-1254. ⟨inria-00352563⟩
578 Consultations
220 Téléchargements
