Memory-manager/Scheduler Co-design: Optimizing Event-driven Programs to Improve Cache Behavior - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Event-driven programming has emerged as a standard to implement high-performance servers due to its flexibility and low OS overhead. Still, memory access remains a bottleneck. Generic optimization techniques yield only small improvements in the memory access behavior of event-driven servers, as such techniques do not exploit their specific structure and behavior. This paper presents an optimization framework dedicated to event-driven servers, based on a strategy to eliminate data-cache misses. We propose a novel memory manager combined with a tailored scheduling strategy to restrict the working data set of the program to a memory region mapped directly into the data cache. Our approach exploits the flexible scheduling and deterministic execution of event-driven servers. We have applied our framework to industry-standard web servers including TUX and thttpd, as well as to the Squid proxy server and the Cactus QoS framework. Testing TUX and thttpd using a standard HTTP benchmark tool shows that our optimizations applied to the TUX web server reduce L2 data cache misses under heavy load by up to 75% and increase the throughput of the server by up to 38%.
bhatia-ismm-06.pdf (293.96 Ko) Télécharger le fichier
inria-00353566 , version 1 (15-01-2009)
  • HAL Id : inria-00353566 , version 1
Sapan Bhatia, Charles Consel, Julia L. Lawall. Memory-manager/Scheduler Co-design: Optimizing Event-driven Programs to Improve Cache Behavior. International Symposium on Memory Management, Jun 2006, Ottawa, Canada. ⟨inria-00353566⟩
Collections
CNRS INRIA INRIA2
156 Consultations
225 Téléchargements
