The k-simultaneous consensus problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
Yehuda Afek
  • Fonction : Auteur
  • PersonId : 857377
Eli Gafni
  • Fonction : Auteur
  • PersonId : 830509
Sergio Rajsbaum
  • Fonction : Auteur
  • PersonId : 830510
Corentin Travers
  • Fonction : Auteur
  • PersonId : 830512
This paper introduces and investigates the k-simultaneous consensus problem: each process participates at the same time in k independent consensus instances until it decides in any one of them. Two results are presented. The first shows that the k-simultaneous consensus problem and the k-set agreement problem are wait-free equivalent in read/write shared memory systems. The second shows that the multivalued version and the binary version of the k-simultaneous consensus problem are wait-free equivalent. These equivalences are independent of the number of processes. An immediate consequence of these results is that the k-set agreement problem and the k-simultaneous binary consensus problem are equivalent. This not only provides a new characterization of the k-set agreement problem but also provides a meaning to the notion of k-set binary agreement.
PI-1920.pdf (156.85 Ko) Télécharger le fichier
inria-00354248 , version 1 (19-01-2009)
  • HAL Id : inria-00354248 , version 1
Yehuda Afek, Eli Gafni, Sergio Rajsbaum, Michel Raynal, Corentin Travers. The k-simultaneous consensus problem. [Research Report] PI 1920, 2009, pp.17. ⟨inria-00354248⟩
188 Consultations
496 Téléchargements
