inria-00355202, version 1
Code injection attacks on harvard-architecture devices
Aurelien Francillon
a, 1Claude Castelluccia a, 1
CCS '08: Proceedings of the 15th ACM conference on Computer and communications security (2008) 15--26
Résumé : Harvard architecture CPU design is common in the embedded world. Examples of Harvard-based architecture devices are the Mica family of wireless sensors. Mica motes have limited memory and can process only very small packets. Stack-based buffer overflow techniques that inject code into the stack and then execute it are therefore not applicable. It has been a common belief that code injection is impossible on Harvard architectures. This paper presents a remote code injection attack for Mica sensors. We show how to exploit program vulnerabilities to permanently inject any piece of code into the program memory of an Atmel AVR-based sensor. To our knowledge, this is the first result that presents a code injection technique for such devices. Previous work only succeeded in injecting data or performing transient attacks. Injecting permanent code is more powerful since the attacker can gain full control of the target sensor. We also show that this attack can be used to inject a worm that can propagate through the wireless sensor network and possibly create a sensor botnet. Our attack combines different techniques such as return oriented programming and fake stack injection. We present implementation details and suggest some counter-measures.
- a – INRIA
- 1 : PLANETE (INRIA Sophia Antipolis / INRIA Grenoble Rhône-Alpes)
- INRIA
- Domaine : Informatique/Cryptographie et sécurité
- inria-00355202, version 1
- http://hal.inria.fr/inria-00355202
- oai:hal.inria.fr:inria-00355202
- Contributeur : Aurélien Francillon
- Soumis le : Jeudi 22 Janvier 2009, 14:20:34
- Dernière modification le : Lundi 16 Février 2009, 15:14:59
Documents associés
Exporter
