Flexible Alignments for Protein Threading - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
We present a new local alignment method for the protein threading problem. Local sequence-sequence alignments are widely used to find functionally important regions in families of proteins. However, to the best of our knowledge, no local sequence-structure alignment algorithm has been described in the literature. Here we model local alignments as Mixed Integer Programming (MIP) models. These models permit to align a part of a protein structure onto a protein sequence in order to detect local similarities. The paper describes two MIP models, compares and analyzes their performance by using ILOG CPLEX 10 solver.
RR-6808.pdf (664.71 Ko) Télécharger le fichier
inria-00355546 , version 1 (23-01-2009)
  • HAL Id : inria-00355546 , version 1
  • PRODINRA : 250027
Guillaume Collet, Rumen Andonov, Nicola Yanev, Jean-François Gibrat. Flexible Alignments for Protein Threading. [Research Report] RR-6808, INRIA. 2009. ⟨inria-00355546⟩
134 Consultations
65 Téléchargements
