Reverse Engineering Prefix Tables - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
The Prefix table of a string reports for each position the maximal length of its prefixes starting here. The Prefix table and its dual Suffix table are basic tools used in the design of the most efficient string-matching and pattern extraction algorithms. These tables can be computed in linear time independently of the alphabet size. We give an algorithmic characterisation of a Prefix table (it can be adapted to a Suffix table). Namely, the algorithm tests if an integer table of size n is the Prefix table of some word and, if successful, it constructs the lexicographically smallest string having it as a Prefix table. We show that the alphabet of the string can be bounded to log2 n letters. The overall algorithm runs in O(n) time.
24-clement.pdf (240.39 Ko) Télécharger le fichier
inria-00359304 , version 1 (06-02-2009)
  • HAL Id : inria-00359304 , version 1
Julien Clément, Maxime Crochemore, Giuseppina Rindone. Reverse Engineering Prefix Tables. 26th International Symposium on Theoretical Aspects of Computer Science STACS 2009, Feb 2009, Freiburg, Germany. pp.289-300. ⟨inria-00359304⟩
313 Consultations
327 Téléchargements
