Semi-Online Preemptive Scheduling: One Algorithm for All Variants - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Tomas Ebenlendr
  • Fonction : Auteur
  • PersonId : 857910
Jiri Sgall
  • Fonction : Auteur
  • PersonId : 857911
We present a unified optimal semi-online algorithm for preemptive schedul- ing on uniformly related machines with the objective to minimize the makespan. This algorithm works for all types of semi-online restrictions, including the ones studied before, like sorted (decreasing) jobs, known sum of processing times, known maximal processing time, their combinations, and so on. Based on the analysis of this algorithm, we derive some global relations between various semi-online restrictions and tight bounds on the approximation ratios for a small number of machines.
29-ebenlendr.pdf (216 Ko) Télécharger le fichier
inria-00359630 , version 1 (09-02-2009)
  • HAL Id : inria-00359630 , version 1
Tomas Ebenlendr, Jiri Sgall. Semi-Online Preemptive Scheduling: One Algorithm for All Variants. 26th International Symposium on Theoretical Aspects of Computer Science - STACS 2009, Feb 2009, Freiburg, Germany. pp.349-360. ⟨inria-00359630⟩
Collections
STACS2009
30 Consultations
153 Téléchargements
