Forward analysis for WSTS, Part I: Completions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Well-structured transition systems provide the right foundation to compute a finite basis of the set of predecessors of the upward closure of a state. The dual problem, to compute a finite representation of the set of successors of the downward closure of a state, is harder: Until now, the theoretical framework for manipulating downward-closed sets was missing. We answer this problem, using insights from domain theory (dcpos and ideal completions), from topology (sobrifications), and shed new light on the notion of adequate domains of limits.
finkel_new.pdf (239.48 Ko) Télécharger le fichier
inria-00359699 , version 1 (09-02-2009)
  • HAL Id : inria-00359699 , version 1
  • ARXIV : 0902.1587
Alain Finkel, Jean Goubault-Larrecq. Forward analysis for WSTS, Part I: Completions. 26th International Symposium on Theoretical Aspects of Computer Science - STACS 2009, Feb 2009, Freiburg, Germany. pp.433-444. ⟨inria-00359699⟩
138 Consultations
184 Téléchargements
