Shortest Paths Avoiding Forbidden Subpaths - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Mustaq Ahmed
  • Fonction : Auteur
  • PersonId : 857927
Anna Lubiw
  • Fonction : Auteur
  • PersonId : 857928
In this paper we study a variant of the shortest path problem in graphs: given a weighted graph G and vertices s and t, and given a set X of forbidden paths in G, find a shortest s-t path P such that no path in X is a subpath of P . Path P is allowed to repeat vertices and edges. We call each path in X an exception, and our desired path a shortest exception avoiding path. We formulate a new version of the problem where the algorithm has no a priori knowledge of X, and finds out about an exception x ∈ X only when a path containing x fails. This situation arises in computing shortest paths in optical networks. We give an algorithm that finds a shortest exception avoiding path in time polynomial in |G| and |X|. The main idea is to run Dijkstra's algorithm incrementally after replicating vertices when an exception is discovered.
05-ahmed.pdf (243.63 Ko) Télécharger le fichier
inria-00359710 , version 1 (09-02-2009)
  • HAL Id : inria-00359710 , version 1
Mustaq Ahmed, Anna Lubiw. Shortest Paths Avoiding Forbidden Subpaths. 26th International Symposium on Theoretical Aspects of Computer Science STACS 2009, Feb 2009, Freiburg, Germany. pp.63-74. ⟨inria-00359710⟩
Collections
STACS2009 TDS-MACS
191 Consultations
309 Téléchargements
