Generating Shorter Bases for Hard Random Lattices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Joël Alwen
  • Fonction : Auteur
Chris Peikert
  • Fonction : Auteur
  • PersonId : 857933
We revisit the problem of generating a “hard” random lattice together with a basis of relatively short vectors. This problem has gained in importance lately due to new cryptographic schemes that use such a procedure for generating public/secret key pairs. In these applications, a shorter basis directly corresponds to milder underlying complexity assumptions and smaller key sizes. The contributions of this work are twofold. First, using the Hermite normal form as an organizing principle, we simplify and generalize an approach due to Ajtai (ICALP 1999). Second, we improve the construction and its analysis in several ways, most notably by tightening the length of the output basis essentially to the optimum value.
06-alwen.pdf (211.34 Ko) Télécharger le fichier
inria-00359718 , version 1 (09-02-2009)
  • HAL Id : inria-00359718 , version 1
Joël Alwen, Chris Peikert. Generating Shorter Bases for Hard Random Lattices. 26th International Symposium on Theoretical Aspects of Computer Science STACS 2009, Feb 2009, Freiburg, Germany. pp.75-86. ⟨inria-00359718⟩
Collections
STACS2009 TDS-MACS
769 Consultations
1039 Téléchargements
