Tractable Structures for Constraint Satisfaction with Truth Tables - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
The way the graph structure of the constraints influences the complexity of constraint satisfaction problems (CSP) is well understood for bounded-arity constraints. The situation is less clear if there is no bound on the arities. In this case the answer depends also on how the constraints are represented in the input. We study this question for the truth table representation of constraints. We introduce a new hypergraph measure adaptive width and show that CSP with truth tables is polynomial-time solvable if restricted to a class of hypergraphs with bounded adaptive width. Conversely, assuming a conjecture on the complexity of binary CSP, there is no other polynomial-time solvable case.
54-marx.pdf (225.85 Ko) Télécharger le fichier
inria-00360101 , version 1 (10-02-2009)
  • HAL Id : inria-00360101 , version 1
Dániel Marx. Tractable Structures for Constraint Satisfaction with Truth Tables. 26th International Symposium on Theoretical Aspects of Computer Science - STACS 2009, Feb 2009, Freiburg, Germany. pp.649-660. ⟨inria-00360101⟩
Collections
STACS2009
56 Consultations
136 Téléchargements
