Interactive Physical Simulation on Multicore Architectures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
In this paper we propose a parallelization of interactive physical simulations. Our approach relies on a task parallelism where the code is instrumented to mark tasks and shared data between tasks, as well as parallel loops even if they have dynamics conditions. Prior to running a simulation step, we extract a task dependency graph that is partitioned to define the task distribution between processors. To limit the overhead of graph partitioning and favor memory locality, we intend to limit the partitioning changes from one iteration to the other. This approach has a low impact on physics algorithms as parallelism is mainly extracted from the coordination code. It makes it non parallel programmer friendly. Results show we can obtain good performance gains.
egpgv09.pdf (579.51 Ko) Télécharger le fichier
Format : Figure, Image
inria-00360131 , version 1 (10-02-2009)
inria-00360131 , version 2 (15-07-2010)
Everton Hermann, Bruno Raffin, François Faure. Interactive Physical Simulation on Multicore Architectures. EGPGV - Eurographics Workhop on Parallel Graphics and Visualization, Mar 2009, Munich, Germany. pp.1-8, ⟨10.2312/EGPGV/EGPGV09/001-008⟩. ⟨inria-00360131v2⟩
733 Consultations
263 Téléchargements
