MANET Router Configuration Recommendations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
This memorandum describes a pragmatic set of configuration recommendations for MANETs, as well as provides a rationale for why these recommendations are sound. While there may be other equally valid ways of configuring a MANET, the recommendations in this memorandum have the merit of being supported by an existence proof (there're running networks in existence, configured according to these recommendations), and they require neither modifications to the IP stack nor to upper-layer protocols or applications.
RR-6852.pdf (461.43 Ko) Télécharger le fichier
inria-00363227 , version 1 (20-02-2009)
  • HAL Id : inria-00363227 , version 1
Thomas Heide Clausen. MANET Router Configuration Recommendations. [Research Report] RR-6852, INRIA. 2009. ⟨inria-00363227⟩
250 Consultations
241 Téléchargements
