On the Rate of Convergence of the Bagged Nearest Neighbor Estimate - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
Bagging is a simple way to combine estimates in order to improve their performance. This method, suggested by Breiman in 1996, proceeds by resampling from the original data set, constructing a predictor from each bootstrap sample, and decide by combining. By bagging an $n$-sample, the crude nearest neighbor regression estimate is turned out into a consistent weighted nearest neighbor regression estimate, which is amenable to statistical analysis. Letting the resampling size $k_n$ grows with $n$ in such a manner that $k_n\to \infty$ and $k_n/n\to 0$, it is shown that this estimate achieves optimal rates of convergence, independently from the fact that resampling is done with or without replacement.
RR-6860.pdf (291.49 Ko) Télécharger le fichier
inria-00363875 , version 1 (24-02-2009)
inria-00363875 , version 2 (26-02-2009)
  • HAL Id : inria-00363875 , version 2
Gérard Biau, Frédéric Cérou, Arnaud Guyader. On the Rate of Convergence of the Bagged Nearest Neighbor Estimate. [Research Report] RR-6860, INRIA. 2009, pp.28. ⟨inria-00363875v2⟩
459 Consultations
235 Téléchargements
