Acyclic edge-colouring of planar graphs
A proper edge-colouring with the property that every cycle contains edges of at least three distinct colours is called an {\it acyclic edge-colouring}. The {\it acyclic chromatic index} of a graph $G$, denoted $\chi'_a(G)$ is the minimum $k$ such that $G$ admits an {\it acyclic edge-colouring} with $k$ colours. We conjecture that if $G$ is planar and $\Delta(G)$ is large enough then $\chi'_a(G)=\Delta(G)$. We settle this conjecture for planar graphs with girth at least $5$ and outerplanar graphs. We also show that $\chi'_a(G)\leq \Delta(G) + 25$ for all planar graph $G$, which improves a previous result by Muthu et al.
Mathématique discrète [cs.DM]
