inria-00368403, version 2
Packaging Mathematical Structures
François Garillot
1Georges Gonthier
2Assia Mahboubi
3Laurence Rideau
4
Theorem Proving in Higher Order Logics 5674 (2009)
Résumé : This paper proposes generic design patterns to define and combine algebraic structures, using dependent records, coercions and type inference, inside the Coq system. This alternative to telescopes in particular allows multiple inheritance, maximal sharing of notations and theories, and automated structure inference. Our methodology is robust enough to support a hierarchy comprising a broad variety of algebraic structures, from types with a choice operator to algebraically closed fields. Interfaces for the structures enjoy the handiness of a classical setting, without requiring any axiom. Finally, we show how externally extensible some of these instances are by discussing a lemma seminal in defining the discrete logarithm, and a matrix decomposition problem.
- 1 : Microsoft Research - Inria Joint Centre (MSR - INRIA)
- INRIA – Microsoft – Microsoft Research Laboratory Cambridge
- 2 : Microsoft Research [Cambridge] (Microsoft)
- Microsoft Research
- 3 : TypiCal (INRIA Saclay - Ile de France)
- INRIA – CNRS : UMR – Polytechnique - X
- 4 : MARELLE (INRIA Sophia Antipolis)
- INRIA
- Domaine : Informatique/Logique en informatique
Mathématiques/Mathématiques générales - Mots-clés : Formalization of Algebra – Coercive subtyping – Type inference – Coq – SSReflect
- Versions disponibles : v1 (16-03-2009) v2 (03-07-2009)
- inria-00368403, version 2
- http://hal.inria.fr/inria-00368403
- oai:hal.inria.fr:inria-00368403
- Contributeur : Assia Mahboubi
- Soumis le : Vendredi 3 Juillet 2009, 19:23:39
- Dernière modification le : Jeudi 9 Juillet 2009, 13:17:34
Documents associés
Exporter
