Average performance of the sparsest approximation in a dictionary - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Given data d ∈ RN, we consider its representation u* involving the least number of non-zero elements (denoted by ℓ0(u*)) using a dictionary A (represented by a matrix) under the constraint kAu − dk ≤ τ, for τ > 0 and a norm k.k. This (nonconvex) optimization problem leads to the sparsest approximation of d. We assume that data d are uniformly distributed in θBfd (1) where θ>0 and Bfd (1) is the unit ball for a norm fd. Our main result is to estimate the probability that the data d give rise to a K−sparse solution u*: we prove that P (ℓ0(u*) ≤ K) = CK( τ θ )(N−K) + o(( τ θ )(N−K)), where u* is the sparsest approximation of the data d and CK > 0. The constants CK are an explicit function of k.k, A, fd and K which allows us to analyze the role of these parameters for the obtention of a sparsest K−sparse approximation. Consequently, given fd and θ, we have a tool to build A and k.k in such a way that CK (and hence P (ℓ0(u*) ≤ K)) are as large as possible for K small. In order to obtain the above estimate, we give a precise characterization of the set [\zigma τK] of all data leading to a K−sparse result. The main difficulty is to estimate accurately the Lebesgue measure of the sets {[\zigma τ K] ∩ Bfd (θ)}. We sketch a comparative analysis between our Average Performance in Approximation (APA) methodology and the well known Nonlinear Approximation (NA) which also assess the performance in approximation.
23.pdf (94.76 Ko) Télécharger le fichier
inria-00369478 , version 1 (24-03-2009)
  • HAL Id : inria-00369478 , version 1
François Malgouyres, Mila Nikolova. Average performance of the sparsest approximation in a dictionary. SPARS'09 - Signal Processing with Adaptive Sparse Structured Representations, Inria Rennes - Bretagne Atlantique, Apr 2009, Saint Malo, France. ⟨inria-00369478⟩
109 Consultations
68 Téléchargements
