s'authentifier
version française rss feed
inria-00369511, version 1
Formal verification of exact computations using Newton's method
Nicolas Julien (Auteur à contacter de préférence) 1, Ioana Pasca () 1
Theorem Proving in Higher Order Logics 5674 (2009) 408-423
Résumé : We are interested in the certification of Newton's method. We use a formalization of the convergence and stability of the method done with the axiomatic real numbers of Coq's Standard Library in order to validate the computation with Newton's method done with a library of exact real arithmetic based on co-inductive streams. The contribution of this work is twofold. Firstly, based on Newton's method, we design and prove correct an algorithm on streams for computing the root of a real function in a lazy manner. Secondly, we prove that rounding at each step in Newton's method still yields a convergent process with an accurate correlation between the precision of the input and that of the result. An algorithm including rounding turns out to be much more efficient.
  • Domaine : Informatique/Calcul formel
  • Mots-clés : formal verification – Newton's method – exact real arithmetic – co-recursive algorithms
  • inria-00369511, version 1
  • oai:hal.inria.fr:inria-00369511
  • Contributeur :
  • Soumis le : Vendredi 20 Mars 2009, 10:39:05
  • Dernière modification le : Mardi 22 Septembre 2009, 14:08:15
tous les articles de la base du CCSd...
