Sparse Super-Resolution with Space Matching Pursuits - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Super-resolution image zooming is possible when the image has some geometric regularity. Directional interpolation algorithms are used in industry, with ad-hoc regularity measurements. Sparse signal decompositions in dictionaries of curvelets or bandlets find indirectly the directions of regularity by optimizing the sparsity. However, super-resolution interpolations in such dictionaries do not outperform cubic spline interpolations. It is necessary to further constraint the sparse representation, which is done through projections over structured vector spaces. A space matching pursuit algorithm is introduced to compute image decompositions over spaces of bandlets, from which a super-resolution image zooming is derived. Numerical experiments illustrate the efficiency of this super-resolution procedure compared to cubic spline interpolations.
41.pdf (344.18 Ko) Télécharger le fichier
inria-00369620 , version 1 (20-03-2009)
  • HAL Id : inria-00369620 , version 1
Guoshen Yu, Stéphane Mallat. Sparse Super-Resolution with Space Matching Pursuits. SPARS'09 - Signal Processing with Adaptive Sparse Structured Representations, Inria Rennes - Bretagne Atlantique, Apr 2009, Saint Malo, France. ⟨inria-00369620⟩
162 Consultations
209 Téléchargements
