Phase Transitions for Restricted Isometry Properties - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Currently there is no framework for the transparent comparison of sparse approximation recoverability results derived using different methods of analysis. We cast some of the most recent recoverability results for `1-regularization in terms of the phase transition framework advocated by Donoho. To allow for quantitative comparisons across different methods of analysis a particular random matrix ensemble must be selected; here we focus on Gaussian random matrices. Methods of analysis considered include the Restricted Isometry Property of Cand`es and Tao, geometric covering arguments of Rudelson and Vershynin, and convex polytopes formulations of Donoho.
45.pdf (163.03 Ko) Télécharger le fichier
inria-00369631 , version 1 (20-03-2009)
  • HAL Id : inria-00369631 , version 1
Jeffrey D. Blanchard, Coralia Cartis, Jared Tanner. Phase Transitions for Restricted Isometry Properties. SPARS'09 - Signal Processing with Adaptive Sparse Structured Representations, Inria Rennes - Bretagne Atlantique, Apr 2009, Saint Malo, France. ⟨inria-00369631⟩
Collections
SPARS09
89 Consultations
106 Téléchargements
