s'authentifier
version française rss feed
inria-00373850, version 1
A distributed algorithm for computing and updating the process number of a forest
David Coudert () a1, Florian Huc 12, Dorian Mazauric 1
22nd International Symposium on Distributed Computing (DISC) 5218 (2008) 500-501
Résumé : In this paper, we present a distributed algorithm to compute various parameters of a tree such as the process number, the edge search number or the node search number and so the pathwidth. This algorithm requires n steps, an overall computation time of O(n log(n)), and n messages of size log_3(n)+3. We then propose a distributed algorithm to update the process number (or the node search number, or the edge search number) of each component of a forest after adding or deleting an edge. This second algorithm requires O(D) steps, an overall computation time of O(D log(n)), and O(D) messages of size log_3(n)+3, where D is the diameter of the modified connected component. Finally, we show how to extend our algorithms to trees and forests of unknown size using messages of less than 2a+4+e bits, where a is the parameter to be determined and e=1 for updates algorithms.
  • Domaine : Informatique/Réseaux et télécommunications
    Informatique/Algorithme et structure de données
  • inria-00373850, version 1
  • oai:hal.inria.fr:inria-00373850
  • Contributeur :
  • Déposé pour le compte de :
  • Soumis le : Mardi 7 Avril 2009, 14:38:06
  • Dernière modification le : Mardi 7 Avril 2009, 14:49:53
tous les articles de la base du CCSd...
