Zero-Content Augmented Caches - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Julien Dusser
  • Fonction : Auteur
  • PersonId : 855370
Thomas Piquet
  • Fonction : Auteur
  • PersonId : 836828
André Seznec
It has been observed that some applications manipulate large amounts of null data. Moreover these zero data often exhibit high spatial locality. On some applications more than 20\% of the data accesses concern null data blocks. Representing a null block in a cache on a standard cache line appears as a waste of resources. In this paper, we propose the Zero-Content Augmented cache, the ZCA cache. A ZCA cache consists of a conventional cache augmented with a specialized cache for memorizing null blocks, the Zero-Content cache or ZC cache. In the ZC cache, the data block is represented by its address tag and a validity bit. Moreover, as null blocks generally exhibit high spatial locality, several null blocks can be associated with a single address tag in the ZC cache. For instance, a ZC cache mapping 32MB of zero 64-byte lines uses less than 80KB of storage. Decompression of a null block is very simple, therefore read access time on the ZCA cache is in the same range as the one of a conventional cache. On applications manipulating large amount of null data blocks, such a ZC cache allows to significantly reduce the miss rate and memory traffic, and therefore to increase performance for a small hardware overhead. In particular, the write-back traffic on null blocks is limited. For applications with a low null block rate, no performance loss is observed.
ics09-dusser.pdf (217.43 Ko) Télécharger le fichier
inria-00374524 , version 1 (25-10-2010)
Julien Dusser, Thomas Piquet, André Seznec. Zero-Content Augmented Caches. ICS 2009 : 23rd International Conference on Supercomputing, Jun 2009, New York, United States. ⟨10.1145/1542275.1542288⟩. ⟨inria-00374524⟩
276 Consultations
463 Téléchargements
