Estimating nonlinearities in twophase flow in porous media.
In order to analyze numerically inverse problems several techniques based on linear and nonlinear stability analysis are presented. These techniques are illustrated on the problem of estimating mobilities and capillary pressure in one-dimensional two-phase displacements in porous media that are performed in laboratories. This is an example of the problem of estimating nonlinear coefficients in a system of nonlinear partial differential equations.
