s'authentifier
version française rss feed
inria-00375427, version 1
Edwards curves and CM curves
François Morain () 1
Résumé : Edwards curves are a particular form of elliptic curves that admit a fast, unified and complete addition law. Relations between Edwards curves and Montgomery curves have already been described. Our work takes the view of parameterizing elliptic curves given by their j-invariant, a problematic that arises from using curves with complex multiplication, for instance. We add to the catalogue the links with Kubert parameterizations of X0(2) and X0(4). We classify CM curves that admit an Edwards or Montgomery form over a finite field, and justify the use of isogenous curves when needed.
  • Domaine : Mathématiques/Théorie des nombres
  • Mots-clés : elliptic curves – Edwards curves – Montgomery curves – complex multiplication.
  • inria-00375427, version 1
  • oai:hal.inria.fr:inria-00375427
  • Contributeur :
  • Soumis le : Mardi 14 Avril 2009, 23:11:29
  • Dernière modification le : Mercredi 15 Avril 2009, 08:28:07
tous les articles de la base du CCSd...
