Benchmarking the BFGS Algorithm on the BBOB-2009 Function Testbed - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
The BFGS quasi-Newton method is benchmarked on the noiseless BBOB-2009 testbed. A multistart strategy is applied with a maximum number of function evaluations of 10^5 times the search space dimension, resulting in the algorithm solving six functions.
wk2031-ros.pdf (719.79 Ko) Télécharger le fichier
inria-00377076 , version 1 (20-04-2009)
  • HAL Id : inria-00377076 , version 1
Raymond Ros. Benchmarking the BFGS Algorithm on the BBOB-2009 Function Testbed. GECCO, Jul 2009, Montréal, Canada. ⟨inria-00377076⟩
88 Consultations
186 Téléchargements
