Benchmarking the NEWUOA on the BBOB-2009 Function Testbed - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
The NEWUOA which belongs to the class of Derivative-Free optimization algorithms is benchmarked on the BBOB-2009 noisefree testbed. A multistart strategy is applied with a maximum number of function evaluations of up to 10^5 times the search space dimension resulting in the algorithm solving 11 functions in 20-D. The results of the algorithm using the recommended number of interpolation points for the underlying model and the full model are shown and discussed.
wk2033-ros.pdf (1.29 Mo) Télécharger le fichier
inria-00377082 , version 1 (20-04-2009)
  • HAL Id : inria-00377082 , version 1
Raymond Ros. Benchmarking the NEWUOA on the BBOB-2009 Function Testbed. GECCO, Jul 2009, Montréal, France. ⟨inria-00377082⟩
191 Consultations
158 Téléchargements
