A unifying and rigorous Shape From Shading method adapted to realistic data and applications
We propose a new method for the Lambertian Shape From Shading (SFS) problem based on the notion of Crandall-Lions viscosity solution. This method has the advantage of requiring the knowledge of the solution (the surface to be reconstructed) only on some part of the boundary and/or of the singular set (the set of the points at maximal intensity). Moreover it unifies in an unique mathematical formulation the works of Rouy and Tourin, Falcone et al., Prados and Faugeras, based on the notion of viscosity solutions and the work of Dupuis and Oliensis dealing with classical solutions and value functions. Also, it allows to generalize their results to the "perspective SFS" problem.
prados-etal-JMIV-2006.pdf (1.12 Mo)
Télécharger le fichier
Format : Figure, Image
