s'authentifier
version française rss feed
inria-00377401, version 2
Dynamic Multi-Armed Bandits and Extreme Value-based Rewards for Adaptive Operator Selection in Evolutionary Algorithms
Álvaro Fialho (Auteur à contacter de préférence) 1, Luis Da Costa () 23, Marc Schoenauer () 123, Michèle Sebag () 123
Learning and Intelligent Optimization (LION 3) 5851/2009 (2009) 176-190
Résumé : The performance of many efficient algorithms critically depends on the tuning of their parameters, which on turn depends on the problem at hand. For example, the performance of Evolutionary Algorithms critically depends on the judicious setting of the operator rates. The Adaptive Operator Selection (AOS) heuristic that is proposed here rewards each operator based on the extreme value of the fitness improvement lately incurred by this operator, and uses a Multi-Armed Bandit (MAB) selection process based on those rewards to choose which operator to apply next. This Extreme-based Multi-Armed Bandit approach is experimentally validated against the Average-based MAB method, and is shown to outperform previously published methods, whether using a classical Average-based rewarding technique or the same Extreme-based mechanism. The validation test suite includes the easy One-Max problem and a family of hard problems known as "Long k-paths".
  • inria-00377401, version 2
  • oai:hal.inria.fr:inria-00377401
  • Contributeur :
  • Soumis le : Mardi 23 Juin 2009, 01:19:22
  • Dernière modification le : Mercredi 7 Avril 2010, 18:30:50
tous les articles de la base du CCSd...
