Fast Precomputed Ambient Occlusion for Proximity Shadows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of graphics tools Année : 2007
Ambient occlusion is used widely for improving the realism of real-time lighting simulations. We present a new method for precomputed ambient occlusion, where we store and retrieve unprocessed ambient occlusion values in a 3D grid. Our method is very easy to implement, has a reasonable memory cost, and the rendering time is independent from the complexity of the occluder or the receiving scene. This makes the algorithm highly suitable for games and other real-time applications.
contactShadows05.pdf (3.27 Mo) Télécharger le fichier
ani.mov (819.79 Ko) Télécharger le fichier
cubedance.mov (932.16 Ko) Télécharger le fichier
supplemental2.pdf (34.77 Ko) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Autre
inria-00379385 , version 1 (28-04-2009)
Mattias Malmer, Fredrik Malmer, Ulf Assarsson, Nicolas Holzschuch. Fast Precomputed Ambient Occlusion for Proximity Shadows. Journal of graphics tools, 2007, 12 (2), pp.59-71. ⟨10.1080/2151237X.2007.10129241⟩. ⟨inria-00379385⟩
956 Consultations
848 Téléchargements
