A Topology-Aware Approach for Distributed Data Reconciliation in P2P Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
A growing number of collaborative applications are being built on top of Peer-to-Peer (P2P) networks which provide scalability and support dynamic behavior. However, the distributed algorithms used by these applications typically introduce multiple communications and interactions between nodes. This is because P2P networks are constructed independently of the underlying topology, which may cause high latencies and communication overheads. In this paper, we propose a topology-aware approach that exploits physical topology information to perform P2P distributed data reconciliation, a major function for collaborative applications. Our solution (P2P-Reconciler-TA) relies on dynamically selecting nodes to execute specific steps of the algorithm, while carefully placing relevant data. We show that P2P-Reconciler-TA introduces a gain of 50% compared to P2P-Reconciler and still scales up.
5-28377.pdf (263.65 Ko) Télécharger le fichier
inria-00379703 , version 1 (29-04-2009)
  • HAL Id : inria-00379703 , version 1
Manal El Dick, Vidal Martins, Esther Pacitti. A Topology-Aware Approach for Distributed Data Reconciliation in P2P Networks. The 13th International European Conference on Parallel and Distributed Computing (Euro-Par), Aug 2007, Rennes, France. pp.318-327. ⟨inria-00379703⟩
137 Consultations
174 Téléchargements
