GénéSyst : Génération d'un système de transitions étiquetées à partir d'une spécification B événementiel - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
The most expensive source of errors and the more difficult to detect in a formal development is the error during specification. Hence, the first step in a formal development usually consists in exhibiting the set of all behaviors of the specification, for instance with an automaton. Starting from this observation, many researches are about the generation of a B machine from a behavioral specification, such as UML. However, no backward verification are done. This is why, we propose the GeneSyst tool, which aims at generating an automaton describing at least all behaviors of the specification. The refinement step is considered and appears as sub-automatons in the produced SLTS.
AFADL04-AvecCopyright.pdf (43.33 Ko) Télécharger le fichier
inria-00384212 , version 1 (13-04-2010)
  • HAL Id : inria-00384212 , version 1
  • ARXIV : 1004.2178
Xavier Morselli, Marie-Laure Potet, Nicolas Stouls. GénéSyst : Génération d'un système de transitions étiquetées à partir d'une spécification B événementiel. Approches Formelles dans l'Assistance au Développement de Logiciels (AFADL'04), Jun 2004, besançon, France. pp.317--320. ⟨inria-00384212⟩
Collections
UGA IMAG CNRS
74 Consultations
189 Téléchargements
