Animal gaits from video : comparative studies
We present a method for animating 3D models of animals from existing live video sequences such as wild life documentaries. Videos are first segmented into binary images on which principal component analysis (PCA) is applied. The time-varying coordinates of the images in the PCA space are then used to generate 3D animation. This is done through interpolation with radial basis functions of 3D pose examples associated with a small set of keyimages extracted from the video. In addition to this processing pipeline, our main contributions are: an automatic method for selecting the best set of key-images for which the designer will need to provide 3D pose examples, and a simple algorithm based on PCA images to resolve 3D pose prediction ambiguities. These ambiguities are inherent to many animal gaits when only monocular view is available.
article3.pdf (7.19 Mo)
Télécharger le fichier
sca04_paper209_video.mpg (27.89 Mo)
Format : Figure, Image
Format : Vidéo
