s'authentifier
version française rss feed
inria-00386475, version 1
Optimizing Low-Discrepancy Sequences with an Evolutionary Algorithm
François-Michel De Rainville a1, Christian Gagné a1, Olivier Teytaud () 234, Denis Laurendeau a1
Genetic and Evolutionary Computation Conference (2009) 8 pages
Résumé : Many elds rely on some stochastic sampling of a given com- plex space. Low-discrepancy sequences are methods aim- ing at producing samples with better space-lling properties than uniformly distributed random numbers, hence allow- ing a more ecient sampling of that space. State-of-the-art methods like nearly orthogonal Latin hypercubes and scram- bled Halton sequences are congured by permutations of in- ternal parameters, where permutations are commonly done randomly. This paper proposes the use of evolutionary al- gorithms to evolve these permutations, in order to optimize a discrepancy measure. Results show that an evolution- ary method is able to generate low-discrepancy sequences of signicantly better space-lling properties compared to sequences congured with purely random permutations.
  • Domaine : Mathématiques/Optimisation et contrôle
  • inria-00386475, version 1
  • oai:hal.inria.fr:inria-00386475
  • Contributeur :
  • Soumis le : Jeudi 21 Mai 2009, 22:15:49
  • Dernière modification le : Vendredi 22 Mai 2009, 08:30:37
tous les articles de la base du CCSd...
