Estimation non paramétrique des valeurs quantiles d'une série temporelle - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Time series forecasting applies to a large variety of problems. In order to forecast future values of a time series, it is frequently more robust to use an estimator based on the median or, more generally, based on a quantile. In this talk, we develop strategies for non-parametric sequential quantile forecasting. We prove the convergence of our strategies under weak assumptions when considering an expert-aggregation strategy relying on Nearest Neighbors experts. To conclude, those strategies are empirically evaluated against real world data - a call center call volume data set.
p50.pdf (120.13 Ko) Télécharger le fichier
inria-00386604 , version 1 (22-05-2009)
  • HAL Id : inria-00386604 , version 1
Benoît Patra. Estimation non paramétrique des valeurs quantiles d'une série temporelle. 41èmes Journées de Statistique, SFdS, Bordeaux, 2009, Bordeaux, France, France. ⟨inria-00386604⟩
48 Consultations
147 Téléchargements
